user_3572401
First like received
I am using CYBT-343026-01 and using platform is WICED 6.1.
I am tring to use sample source-cord of hci_audio_gateway,to see how it is working.
But after download the HEX to CYBT-343026-01,The port output is garbled in both port,so that I can not read it.
Another,when I use sample source-cord of Hello_sensor,there is one port only that has output.
Why this time two port bath has output.WICED Studio Bluetooth Forums
Is there any way that I can do to solve this problem?
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
Are you using the 343026-EVAL board?
Please turn off the HCI UART(SW4) after you program the board. Then turn on the PUART (SW5).
Find the PUART port on your computer. The UART app in your computer should set to 115200, flow control off.
Push the reset button on the board. You will see the log.
Please let me know if you have any problem.
Owen_Zhang123
