Jun 27, 2021
10:03 PM
Jun 27, 2021
10:03 PM
Is it correct to understand that the output value described in the data sheet is the result when (maximum transmission power) is set as follows?
BDR / EDR + 12dBm setting → BDR + 12dBm (typ) / EDR + 9dBm (typ)
BLE + 8dBm setting → BLE + 9dBm (max)
Labels
WICED Studio Bluetooth
10:04 PM
Jun 27, 2021
10:04 PM
Hi KeOn
Set .max_pwr_db_val in wiced_bt_cfg_settings_t to 12.
This is the value when no other power adjustment API functions are called.
What is a power adjustment API function?
Wiced_bt_dev_set_adv_tx_power ()
Wiced_bt_dev_set_tx_power ()
