[CYBT-343026-01]TxPower Maximum transmit power setting
KeOn_
Distributor - Macnica (Japan)
100 sign-ins 25 replies posted 10 solutions authored
Is it correct to understand that the output value described in the data sheet is the result when (maximum transmission power) is set as follows?
BDR / EDR + 12dBm setting → BDR + 12dBm (typ) / EDR + 9dBm (typ)
BLE + 8dBm setting → BLE + 9dBm (max)
YoJa_3107936
100 sign-ins 50 sign-ins First like given
Hi KeOn
Set .max_pwr_db_val in wiced_bt_cfg_settings_t to 12.
This is the value when no other power adjustment API functions are called.
What is a power adjustment API function?
Wiced_bt_dev_set_adv_tx_power ()
Wiced_bt_dev_set_tx_power ()
YoJa_3107936
Hi KeOn
