CYBT-343026-01 Tx output power for Bluetooth Classic on mbt
shsac_2001676
CYBT-343026-01 Datasheet said, Tx output power is +12dBm for BT Classic.
However, "mbt" max power said 3dBm.
Which is correct ?
And, Can we set the max power(+12dBm) on mbt ?
AnjanaM_61
5 comments on KBA First comment on KBA 5 questions asked
Hi ,
mbt documentation is a generic one , so its mentioned 3dBm.
CYBT-343026-01 do support till +12dBm and you can test and verify .
Refer : Datasheet - http://www.cypress.com/documentation/datasheets/cybt-343026-01-ez-bt-wiced-module
            Blog - Configuring Transmit (Tx) power on the CYW20706
Thanks & Regards,
Anjana
AnjanaM_61
Hi ,
Thanks & Regards,
Anjana
