NeDh_4602711
50 replies posted 25 replies posted 25 sign-ins
This post is related to https://community.cypress.com/t5/WICED-Studio-Bluetooth/OTA-firmware-update-on-CYBT-343026-01/m-p/95... I got succeeded in the OTA firmware update. But Currently, I am facing the problem that the MAC address keeps changes if the battery is removed and plugged again. This not happen if I flash the firmware from the header pin.
Could you please let me know what I am doing wrong?
Neeraj
AnjanaM_61
First comment on KBA 5 questions asked First question asked
Hi Neeraj,
I think in one of your previous thread , you said you will be using similar implementation suggested here: https://community.cypress.com/t5/ModusToolbox-Blog/How-to-generate-BD-address-randomly-and-save-in-f...
Even after using this are you seeing BD address getting changed after upgrades? If then, can you please confirm the config.c file settings for BD address you are using ? Also please check if you have disabled privacy or not in application code using API  wiced_bt_ble_enable_privacy ( WICED_FALSE );
Anjana
AnjanaM_61
Hi Neeraj,
Anjana
