CYBT-343026-01 GPIO Toggle Issue
NaDo_1344206
Welcome!
I had attached snapshot of error I am getting in WICED studio, below are the instructions.
     wiced_hal_gpio_set_pin_output(WICED_GPIO_PIN_LED_2,0);
     wiced_rtos_delay_milliseconds(500,KEEP_THREAD_ACTIVE );
     wiced_hal_gpio_set_pin_output(WICED_GPIO_PIN_LED_2,1);
This program is to toggle LED using delay function.
Please help me to resolve same.
Hi Nainesh,
Can you please confirm if you are using CYBT-343026 or not?
wiced_rtos_delay_milliseconds function is not exposed/ supported for 20706 . You may have to use timers for delay.
Please refer to gpio snip ( /20706-A2_Bluetooth/apps/snip/hal/gpio ) as reference for toggling LED .
Also please note, don't use while(1) loop inside Application_start.
Anjana
