Studio Bluetooth
NaDo_1344206
Welcome!
Hi All,
I had tried to ON/OFF LED connected as per attached schematic but not able to do using attached code in notepad++.
I had used CYBT-343026-01 based custom board WICED Studio ( WICED-SDK Version: Wiced_006.002.001.0002 , b94b1cc047c6cbaa4d2aa50bd36d6af921998270 )
I am able to program device but not effect on LED.
Please help if I had anything wrong in code.
Nainesh Doshi.
DheerajPK_41
Moderator 750 replies posted 500 likes received 500 replies posted
I think you have used the timers wrongly.
Could you please try the attached code - sample.c. It is coded to blink LED on WICED_P26 periodically with 1sec timer.
If it works you can add other LEDs also in the code.
Please make sure you have mapped the correct pins in the code as per the customized board schematics.
-Dheeraj
