YoJa_3107936
50 sign-ins First like given 100 replies posted
Hi
The customer is considering to use [CYBT-343026-01] module.
They want to talk about the following two points around the antenna designe.
1. Could you give them some advice when measureing the antenna characteristics(when assembled in a housing),
and the antenna around the design stage?
2. Previously, when using another company's module,
the module manufacturer sent the CAD data of the housing and gave some advice to customer.
In addition, the antenna characteristics were also measured while actually being incorporated into the product.
Is it possible to do the same thing with Cypress or some other company?
Yang
BoonT_56
1) Measuring antenna characteristics is beyond the scope of this forum. However from experience in IoT products, antenna performance will
be affected by (a) metallic housing, and (b) hands (e.g. remote control). Otherwise, always try to position the module in a corner with the
antenna main beam "pointing" away from the host PCB.
2) Page 6 and 7 of the module datasheet suggested some guidelines on the PCB layout.
BoonT_56
BoonT_56
A useful blog on module placement
EZ-BLE™ Module Placement – KBA97095
TakashiM_61
1000 replies posted 500 solutions authored 750 replies posted
Dear Thread Author,
For more further discussion, it would be better to contact to Cypress local sales representative and/or local FAE.
If you don't need any further technical support for this thread, please let us know.
Thank you.
Hi TakashiM_61
Thank you for replying my thread.
I will ask the local team.
Please close this case.
Yang
