YoJa_3107936
50 sign-ins First like given 100 replies posted
Hi
Customer got the below number(20 digits) from QR-Code.
・B3430260103184414HDD
・B3430260103183914ACJ
So they would like to confirm the below information.
1, What kind of information is linked to this data?
1, Is there any information that can be read from this data format?
(Production date, production plant, Lot No. etc.)
3, Is the number of digits changing from 20 digits?(Is there a possibility other than 20)
Previous related link:
https://community.cypress.com/message/198099?et=watches.email.thread#198099
Yang
Hi Yang,
2d barcode content: “B012011000418101725B” (eg: CYBLE-012011-00 Rev04 module)
The 2D barcode contents should be:”M-PPPPPP-rr RR’’+ “YYWW-F-NNNn”(which is defined in barcode format, for the example:B-012011-00 04 1810-1-725B”.
Detail meaning see as below explanation:
Barcode contents definition:
Format:  MPPPPPPrrRRYYWWFNNNn
Total: 20 digits.
M stands for BLE type, presently only ‘B’
PPPPPPrr stands for part type, example: 01201100
RR stands for final assembly revision, example: 01
YY stands for year, example: 18
WW stands for week in a year, example: 23
F stands for Manufacture Vendor, example: 1 for Sigmatron
1----Sigmatron
2----USI
3----AsteelFlash
4----Celestica
5----(undefined)
NNN stands for number of panels(001~zzz), example: 001
n stands for sequence number of board on panel(0,1~9,A,B~Z), example: 0 (max 36-up panel)
special notes:
0------1st unit
1------2nd unit
9------10th unit
A------11th unit
B------12th unit
Z------36th unit
For example, B012011-00, revision 01, made in 2018, week23, Manufacture Vendor (such as 1), the no.1 board on panel 001, the barcode should be: B0120110001182310010
However I don't understand how this will help you. Can you please let us know what is the real requirement of unique ID?
Anjana
YoJa_3107936
Hi
Could you give me the answer ASAP?
Yang
TaGo_2353976
Level 4
Level 4
Hi Cypress guys,
We know the answer of #1 by my other thread that this number is unique ID.
Previous my thread: https://community.cypress.com/thread/42094
so please tell me for following questions.
>2. Is there any information that can be read from this data format?
>3. Will these number of digits be increased/decreased from 20 digits?
>   (I mean that amount of this number never is changed from 20 digits?)
Thank you.
--TAK
Hi Cypress members
Add below information.
Customer wants to manage this ID(QR-CODE) at their production plant,
so could you tell us the answer ASAP?
Yang
Hi Yang,
Total: 20 digits.
1----Sigmatron
2----USI
3----AsteelFlash
4----Celestica
5----(undefined)
special notes:
0------1st unit
1------2nd unit
9------10th unit
A------11th unit
B------12th unit
Z------36th unit
Anjana
Hi Anjana
Thank you for your answer very much.
The customer strictly manages the product.
For example, if the ID (QR-CODE) is not 20 digits, their management system will handle the alarm.
They will confirm with your company if this IC has a problem.
I will close this case.
Yang
