[CYBT-343026-01] About MaxPawor setting when performing Radio TX Test
KeOn_
Distributor - Macnica (Japan)
100 sign-ins 25 replies posted 10 solutions authored
Is it okay to recognize that + 12dBm cannot be set with mbt.exe for the Radio TX Test item?
YoJa_3107936
100 sign-ins 50 sign-ins First like given
Hi KeOn
The setting + 12dBm cannot be set on the MBT tool, but the +12dBm test can be supported if the change is supported on the source code.
Please refer to the below two for the solution.
About the first method
Https://community.cypress.com/thread/34308?q=Configuring%20Transmit%20(Tx)%20power%20on%20the%20CYW2...
Please refer to the link below as well.
Https://community.cypress.com/docs/DOC-18312
About another method
The test can be measured at +12dBm using the CyBluetool tool.
Please check the tool download and User Guide information at the link below.
Https://community.cypress.com/docs/DOC-16475
Yang
YoJa_3107936
Hi KeOn
Yang
