Sep 20, 2021
10:02 PM
Sep 20, 2021
10:02 PM
Hi
About the current consumption of BLE described in the data sheet
"+ 9.0dBm" → + 8dBm
Is it correct in the recognition that it is set?
"+ 9.0dBm" → + 8dBm
Labels
WICED Studio Bluetooth
10:03 PM
Sep 20, 2021
10:03 PM
Hi Misa
Actually, it would be nice to be able to actually measure it, but above, basically
wiced_bt_cfg_settings_t
You can set the maximum transmission power with.
If you want to change dynamically
wiced_bt_dev_set_adv_tx_power ()
wiced_bt_dev_set_tx_power ()
It means that you can intentionally reduce the power.
10:03 PM
Sep 20, 2021
10:03 PM
Hi Misa
