[CYBT-343026-01] About DownSampling(BT module,I2S slave)
MiSa_2357281
Distributor - Macnica (Japan)
5 replies posted 250 sign-ins First solution authored
Hello
I think 96kHz_16bit Stereo Or When receiving 88.2kHz_16bit Stereo with I2S slave It is not necessary to specify them on WICED, and Sampling Frequency on WICED.
48kHz Or 44.1kHz and Is it okay to understand that the data received by the private internal logic is DownSampled just by specifying it?
YoJa_3107936
100 sign-ins 50 sign-ins First like given
Hi MiSa
It is necessary to set the I2S Slave and A2DP sampling frequency as usual
(similar to the case without downsampling),
but the downsampling process itself is performed inside CYW20706, so be especially careful.
PREVIEW
YoJa_3107936
Hi MiSa
PREVIEW
