Could you let me know the behavior in I2S slave mode ?
- Can 343026 handle higher sampling rate then 48 kHz ?
- Can 343026 handle longer sampling data then 16 bits ?
According to the data sheet, 343026 is supported up to a maximum of 3.072 MHz.
48 kHz * 16 bits * 2 channels = 1.536 Mbps.
So, it looks 343026 may use higher or longer data then 48 kHz, 16 bits.
For examples, is 343026 able support the following settings ?
Case 1) 96 kHz, 16 bits, 2 channels
Case 2) 48 kHz, 24 bits, 2 channels
24 bit configuration is not supported by Cypress devices, therefore case 2 will not work for CYBT343026 module.
You can use configuration given in case 1.
Hello MaMi_3520196,
Please refer PCM/I2S Clock setting in CYW20706 and WICED Studio Bluetooth Forums.
Let us know if this clarifies your doubt.
Hi SheetalJ_96,
I had already read them.
But there is less information about I2S slave in them.
So could you let me know the details when I2S slave mode ?
Thank you for rapidly supporting.
Hi SheetalJ_96
Excuse me for cutting in.
MaMi is my partner.
I confirmed the DataSheet (P38) of 20706, and added below question.
>The clock rate in master mode is either of the following:
>■ 48 kHz x 32 bits per frame = 1.536 MHz
>■ 48 kHz x 50 bits per frame = 2.400 MHz
Customer focuses on [48 kHz x 50 bits per frame = 2.400 MHz].
This is possible(48kHz_24bit) because it is less than 50 bits.
Could you tell how many bit patterns are possible?
And why do you write 50 bits?
Yang
Hi Yang,
For I2S master, 48 kHz x 50 bits per frame = 2.400 MHz configuration is not supported. I will initiate the process to make the update in datasheet. Apologies for the confusion caused.!
Please refer PCM/I2S Clock setting in CYW20706 for updated I2S master-slave configurations.
