Nov 28, 2019
01:04 AM
Nov 28, 2019
01:04 AM
Can we use 3.073MHz as I2S clock for "48kHz, 16 bits, 2 channels" ?
The data rate is "48kHz, 16 bits, 2 channels -> 1.536 Mbps".
So, the clock rate is higher than the data rate.
Can CYBT343026 accept the settings ?
If yes, I think some padding data will be inserted in it.
Is the followings correct ?
WS: 48kHz
<Lch(16bit: MSB->LSB), padding(16bit)>, <Rch(16bit, MSB->LSB), padding(16bit)>, <Lch, padding>, <Rch, padding>, ...
Labels
01:33 AM
Dec 10, 2019
01:33 AM
The only configuration we support is 16bit data with 32 Clocks. MSB Stuffing is not supported.
Please refer PCM/I2S Clock setting in CYW20706 for the allowed clock configuration.
