chho_4472146
I want to use the CYBT-333032-02 with linux via HCI UART inteface.Do i need to install a driver or linux will autodetect the module ?
I found that the CySmart is only supported on windows pc and also the ModusToolbox™ Software Environment is available on windows and linux but doesn't support the CYBT-333032-02.
Many thanks for help
AnjanaM_61
10 questions asked 5 comments on KBA First comment on KBA
Q) I want to use the CYBT-333032-02 with linux via HCI UART inteface.Do i need to install a driver or linux will autodetect the module ?
A : CYBT-333032-02 is supported in WICED studio 6.4 SDK which is available in linux as well. Install SDK from : WICED Studio Wi-Fi/Combo Docs & Downloads
Q) CySmart
CySmart is available only in Windows PC. However if you are looking for a BLE client app for testing, CySmart mobile app is available for Android and iOS : https://www.cypress.com/documentation/software-and-drivers/cysmart-mobile-app
Anjana
AnjanaM_61
Q) CySmart
Anjana
