Jun 22, 2020
06:01 AM
Jun 22, 2020
06:01 AM
Hi all,
I have a custom module based on CYBT-333032-02, and it has only the UART pins out , and it is used directly on another custom board that supports those pins, and the board is running Linux to attach the detected UART module which is CYBT-333032-02.
So the main question is how to flash that module with WICED ? and what equipment do I need for that ?
Thanks , Talel
Jun 22, 2020
08:43 AM
Jun 22, 2020
08:43 AM
You can generate the .hex or .hcd using WICED, and try using chipload tool.
How to use Chipload: Programming using ChipLoad.exe
Please find the attached file.
-Dheeraj
