AsRa_264661
Level 4
Level 4
50 replies posted 25 replies posted 10 likes received
Hi All, DheerajP_41
Im trying to run my application with coin cell. I flashed "switch on/off" example code.
Jumper setting i changed to source power from coin cell.
but still my application did not starts/ works. But when i power using USB it works.
anything workaround required from firmware side?
Ashok r
Hi Ashok,
Unfortunately current CYBT-213043-MESH board have some leakage current; Because of which it can't be powered by coin cell battery.
Sorry for the inconvenience caused.
Anjana
DheerajPK_41
Hi AsRa_264661​,
I could see similar issues at my side also. We are trying to figure out the actual issue. I will let you know the updates.
Mean time please make sure that you have connected the jumper correctly to take power from coin cell.
Also LED and other power consuming peripherals may not work in the cell powered situation.
-Dheeraj
Hi Ashok,
Anjana
