Oct 01, 2021
12:22 PM
Oct 01, 2021
12:22 PM
Hi, I am working with the CYW4343 and am trying to connect via bluetooth and access GATT services. I tested the different projects available in Wiced like (simple_ble_peripheral and wifi_introducer) everything works fine with IOS and Androit as a client. The problem occurs when I use Windows 10 as a client. Once connected, getting services is very slow and unstable. Even the pairing sequence is not really stable. I notice that on some request, the device goes on hold and seems to be reaching timeouts. Is it possible to have a sample project tested under windows 10 which contains GATT services. Otherwise someone able to help us with the parameters of the Ble stack that could be causing these problems. I include as attachments a picture of the output log of a IOS connection and read for the Wifi_introducer project and a output as a widows 10 Client.
Labels
03:48 AM
Oct 12, 2021
03:48 AM
To avoid unexpected bugs, please use the CySmart tool and the CY5677 CySmart BLE 4.2 USB Dongle, to debug your BLE application and GATT services. See below:
https://www.cypress.com/documentation/software-and-drivers/cysmart-bluetooth-le-test-and-debug-tool
And you can also try another USB Bluetooth LE module (besides the built-in module of your computer), with your current test environment, to see if the original Bluetooth LE module was malfunctioning.
