BT_DEVICE_ADDRESS
stte_3997901
First like given
I try to use the hello_sensor example with BT_DEVICE_ADDRESS=207060123456
The complete call to the make_target is
"demo.hello_sensor-CYW920706WCDEVAL download VERBOSE=1 BT_DEVICE_ADDRESS=207060123456"
But The "Hello" sensor go in advertising with different address.
What I'm doing wrong?
I have not changed the example.
BoonT_56
You must disable the below API in application_init, then it will work.
wiced_bt_ble_enable_privacy ( WICED_TRUE );
BoonT_56
