Niku_4135181
5 sign-ins Welcome!
hi
I am attempting to set the I2S interface in SLAVE mode for the Call Audio configuration.
So I have one doubt regarding this :
In slave mode do we need to set the WBS and I2SPCM sample rate and clock rate.
If yes then , As the clock will be provided from external source then why we need to set the clock and sample rate?
Thanks for your help
Nitin kumar
HI Nitin,
I am sorry, we won't support this chip in community. You may have to contact our local FAE or sales for support.
Anjana
AnjanaM_61
First comment on KBA 5 questions asked First question asked
HI Nitin,
Could you please confirm which chip and profile are you using?
Please check if this blog will help to get your answer: PCM/I2S Clock setting in CYW20706
Anjana
Hi
Chip is W-LAN+Bluetooth Combo Module CYW89359.
I want to configure call audio for HFP .
For the same I want to know the slave configuration related parameters we need to set.
Nitin
HI Nitin,
Anjana
