I found the following description in the datasheet of CYBT-3330xx-02.
Is the MIC-JAPAN regulation for CYBT-333032-02 approved for the antenna listed in Table 6?
Only FCC is listed here, but can I use without additional application and testing for MIC-JAPAN regulation ?
RyKi
The certificates and test reports of CYBT-333032-02 can be found in KBA225653.
You will notice the EUT description in the report of TELEC:
And there is a note in the MIC-Japan certificate 201-180688:
So I think the decision should be left to you.
From the datasheet of CYBT-3330xx-02:
MIC Japan
CYBT-3330xx-02 is certified as a module with certification number 201-180688. End products that integrate CYBT-3330xx-02 do not need additional MIC Japan certification for the end product.
The end product can display the certification label of the embedded module.
For more infomation, see:
https://www.cypress.com/file/464611/download
Hello Charles_Lai-san,
I think you have not got my point yet, so let me explain it again.
We are going to use an external antenna this time.
Can I use Table 6 for the specifications of the antenna that obtained the MIC-JAPAN regulation for CYBT-333032-02?
Regars,
RyKi
Thank you for your courteous reply.
RyKi
