Hi ,
BT 和BLE同时使用的话,是需要配对连接执行两次,那么BT跟BLE的地址是不同的吗
广播类型为可连接的非定向广播, BLE如果使用public地址的话,是否跟BT地址相同呢
Leo
Not sure if I translated your query correctly.
If the query is as below:
1. 'Will BT classic and BLE will be using same BD address ', then the answer is Yes, both will be using same BD address.
2. Pairing for BT and BLE : BR/EDR and BLE have separate pairing and IO capabilities parameters and events. Thus both are handled separately . For example, check parameters of pairing_io_capabilities_ble_request , pairing_io_capabilities_br_edr_request and events BTM_PAIRING_IO_CAPABILITIES_BLE_REQUEST_EVT , BTM_PAIRING_IO_CAPABILITIES_BR_EDR_REQUEST_EVT in wiced_bt_dev.h
You may read through WBT101-06A-ClassicBluetooth-Basic.pdf and WBT101-04B-BLE-Ntfy-Sec.pdf for Handling pairing in BT & BLE in WICED SDK ( CypressAcademy_WBT101_Files/Labmanual at master · cypresssemiconductorco/CypressAcademy_WBT101_Files... )
Anjana
Anjana
Hi Anjana ,
Thanks for your clarify.
BR,
Leo
