- Email to a Friend
I'm currently debugging some audio quality issues our system is having with over A2DP (dropouts, pops, crackles), notably using phones transferring high data rates in the order of 40-50kB/s. Other phones with lower data rates in the order of 30kB/s do not suffer such problems. These figures were measured over the air using a bluetooth analyser.
My question is: what is the best way to configure the A2DP sink on our CYBT343026 in order to eliminate these issues? Currently it is setup like the example code given:
/** A2DP sink configuration data */
wiced_bt_a2dp_config_data_t handsfree_audio_config =
.feature_mask = 0, /* feature mask */
.codec_capabilities =
.count = sizeof(handsfree_audio_codec_capabilities) / sizeof(handsfree_audio_codec_capabilities[0]),
.info = handsfree_audio_codec_capabilities, /* codec configuration */
.p_param =
.buf_depth_ms = 300, /* in msec */
.start_buf_depth = 50, /* start playback percentage of the buffer depth */
.target_buf_depth = 50, /* target level percentage of the buffer depth */
.overrun_control = WICED_BT_A2DP_SINK_OVERRUN_CONTROL_FLUSH_DATA,/* overrun flow control flag */
.adj_ppm_max = +300, /* Max PPM adjustment value */
.adj_ppm_min = -300, /* Min PPM adjustment value */
.adj_ppb_per_msec = 200, /* PPM adjustment per milli second */
.lvl_correction_threshold_high = +2000, /* Level correction threshold high value */
.lvl_correction_threshold_low = -2000, /* Level correction threshold low value */
.adj_proportional_gain = 20, /* Proportional component of total PPM adjustment */
.adj_integral_gain = 2, /* Integral component of total PPM adjustment */
Also, is there any way to detect/quantify packet loss, or any general failures with A2DP? Would also appreciate any additional info on the different parameters that can be affected!
Nick
- a2dp
- Email to a Friend
Hi Nick,
The audio dropouts may happen because of a number of reason - peer device being used, test env, rf/board design, etc. The default parameters should work well on most parts.
Could you please get us the over the air logs ?
Anjana
- Email to a Friend
Can we please get this. I am also looking for same information but not able to find any.
- Email to a Friend
Just out of curiosity, what phones are you seeing this issue with?
- Email to a Friend
I am not observing issues with phone. Need to check if these are configurable or not.
- Email to a Friend
Hi Nick,
Anjana
