Hi DJJQ_4100866,
Which WICED version and cypress chip/product are you using? Are you trying to program a device?
You do not need to import the 43xxx_Wi-Fi workspace to WICED SDK explicitely. After installing, you can see different workspaces in Project Explorer window. From the attached snapshot, the installing or 'importing' procedure doesn't look correct to me.
I would suggest you to refer WICED-Studio-6.2\43xxx_Wi-Fi\doc\WICED-QSG.pdf to get start with the WICED Studio and programming the device. Let me know at what stage you are getting the errors.
Hi DJJQ_4100866,
