Hi there,
Is there a programming kit available for programming of the TLE4959x EEPROM? I would like to evaluate them and I was wondering if such a kit was available. If not, is there a recommended programming circuit I could build to test them with?
Adam
Speed sensor
- eeprom
- programming
Hi @AdamR ,
The tool to evaluate TLE4929C/TLE4959x in the application is the well known as PGSISI2.
Additionally there is a specific daughter-board which customizes the PGSISI2-box to the TLE4929C/TLE4959x.
See the picture below to see how the PGSISI2-box and corresponding daughter board looks like -
The complete evaluation-kit is named “TLE4986C PROGRAMMERKIT” and can be ordered at Infineon using the ordering-number “SP001012368”.
For customers already owning a PGSISI2 the daughter-board can also be ordered. The name is “TLE4986C EVALBOARD” and can be ordered by ordering-number “SP001012364”.
Hope you got the answer to your question.
Sunil.
Hi Sunil,
Thank you very much for your answer.
Are you able to please provide a link to the “TLE4986C PROGRAMMERKIT” as I am struggling to find it on Infineon's website, and I am not sure which resellers would stock this?
Adam
Hi @AdamR ,
Please visit the links to some distributors below :
https://www.avnet.com/shop/apac/products/infineon/tle4986c-programmerkit-3074457345649333544/
https://www.rutronik24.com/product/infineon/tle4986c/7557844.html
Do not worry when Infineon-stock is zero and delivery-time is 1 to 3 weeks. The boards are assembled in the laboratory and will be shipped as soon the order is received.
Thanks & regards,
Sunil.
