Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
Translation_Bot
100 likes received
How to use the iMAT - Speed Viewer to Evaluate the TLE4922 sensor' signal.
- Minimum airgap assessment
- Maximum airgap assessment
- Maximum runout acceptance
- Bent tooth detection
- Phase accuracy
and how to get the iMAT - Speed Viewer.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8-%E7%A3%81%E6%80%A7/How-to-use-the-iMAT-Speed-Viewer-to-Evaluate-the-TLE4922-sensor-signal/td-p/738709
Translation_Bot
100 likes received
Hi @Gagilan
iMAT has not been released to the public and please use https://www.infineon.com/dgdl/Infineon-GUI%20for%20Speed%20Sensor%20TLE4922%20-%202GO%20Kit-v01_02- Software-v01_02-EN.zip?fileId=5546d462636cc8fb016388821c8f16e8 &da=t instead.
Best, Julis
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8-%E7%A3%81%E6%80%A7/How-to-use-the-iMAT-Speed-Viewer-to-Evaluate-the-TLE4922-sensor-signal/m-p/740783
Translation_Bot
100 likes received
Hi, @Gagilan
May I know which hardware platform are you using? TLE4922 MS2GO?
Thanks, Julis.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8-%E7%A3%81%E6%80%A7/How-to-use-the-iMAT-Speed-Viewer-to-Evaluate-the-TLE4922-sensor-signal/m-p/739492
Translation_Bot
100 likes received
HI, Julis
Yes, The hardware is TLE4922 MS2GO.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8-%E7%A3%81%E6%80%A7/How-to-use-the-iMAT-Speed-Viewer-to-Evaluate-the-TLE4922-sensor-signal/m-p/739496
Translation_Bot
100 likes received
Hi @Gagilan
Best, Julis
Translation_Bot
100 likes received
Hi, Julis.
Thanks a lot for your support.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8-%E7%A3%81%E6%80%A7/How-to-use-the-iMAT-Speed-Viewer-to-Evaluate-the-TLE4922-sensor-signal/m-p/740815
