Hello Team,
Please suggest a latch-type hall sensor that withstands lower temperature rating up to -55C. The package is not a concern yet. Below are details of the hall sensor specifications. This we required for Aerospace and defense application
Voltage – 2.7V to 5V/24V
Output type – Open drain/open collector
Technology – Hall effect
Type - Latch
Polarization – South /North
Package – Any
Temperature - -55 °C to greater than +125 °C
Sayali Shinde
Hii Sayali,
Thank you for reaching us out. As a response for the question asked, I would like to highlight few points.
1.) The minimum operating and storage temperature hall based latch type sensor is -40 C, there are no detailed test which suggest the behaviour and the performance of the sensors below -40 C.
2.) Basically, once taken below this temperature, nothing can be commented whether the sensor would work even after going to temperatures greater than -40 C. Therefore, there is no guarantee that sensor would work. It may or may not work.
Hope this clarifies.
Thanks and Regards,
Adithya
Hello Adithya,
Thank you for reply. Can you customize hall sensor for lower temperature requirement.
Sayali
Hello Adithya,
waiting for reply. If you can support for cusotmize hall sensor for lower temperature rating, what will be the MOQ or any NRE charge.
Sayali
Hi Sayali,
We are in touch with the concerned team. I will get back to you once we get update.
Thanks and regards,
Adithya
Hello Adithya,
Any response from concerned team.
Sayali
Hi Sayali,
Thank you for your patience.
All the automotive hall sensors are defined for the junction temperature of Tj = -40°C up to 195°C. For transportation and storage purposes, it can be brought down to -55°C for 2000 cycles. This is only for storage, NOT for Operation.
Thanks and regards,
Adithya
Hi Sayali,
I hope your issue is solved. We will be resolving this thread.
Thanks and regards,
Adithya
