The CY7C0833V data sheet (Doc# 38-06059 Rev. AA, 8/1/2017) notes in fig 1 that the CE and CE/ pins are not applicable for this part and must be tied off to VSS and VDD, respectively [to always enable them].
No such notes are listed in Table 3. Is this device truly intended to be on a bus by itself as it cannot be deselected?
Dual Port
Part Number Query
Hi
Yes that is the correct interpretation for CY7C0833V device. To add on to it, You can however share the bus with other devices since OE# signals can be used to put the get control of the bus.
In the Pin definition on Page 6, we try to capture the functionality/
Please have a look at Note 28.
*ISB1, ISB2, ISB3 and ISB4 are not applicable for CY7C0833V because it can not be powered down by using chip enable pins.
Nilesh
Hi
Nilesh
