Suggest a power switch details below,
High-Side Switch:
Voltage Range : 0V to 16V DC
Load Current : 0.5A, 2A, 5A and 12A
PWM Switching Frequency : Up 100KHz
Low-Side Switch:
Please suggest me a Low-Side and High-Side PWM based switch.
Thank you.
Gopal
I am looking into your request. Meanwhile, you can also have a look at Infineon smart switch finder tool: Smart Switch Finder .
Anshika
Thank you. This application is for automotive.
Gopal
Any update.
We have many products matching with voltage and current as you need. But PWM switching frequency criteria does not successfully match with every product.
As you have not mentioned the channels and Rds(on) required, I have prepared a table of our products category with their respective limits.
Sr.No. |
Product Category |
Min-Max Supply Voltage |
ILOAD(Nominal) |
PWM frequency |
High-Side Switch |
1. |
-0.3V - 28V |
0.5A - 10 A |
Upto 200Hz |
2. |
-0.3V – 28V |
Upto 31.3 A |
<20kHz |
Low-Side Switch |
1. |
Vds upto 42V |
Upto 5 A |
<=50kHz |
PWM criteria of 100kHz cannot be fulfilled. If it is okay go for lower PWM frequency then please have a look at products mentioned above.
If you still need a particular part number recommendation, let me know the number of channels, Rds(on) limit(low/high/any).Also,if there is a specific product package requirement.
Anshika
Hi Ma'am,
I verified the datasheets, the data related PWM frequency didn't noticed.
Please help me.
Thank you.
Gopal
