TominMaryland
5 replies posted 5 questions asked 5 sign-ins
what is the purpose of SV6 pin 1 ?
The pin 1 header SV6 is not connected to SW3?
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
    Thank you posting on the Infineon Community.
The pin header SV6, is basically used as a test point for the switch S3. It cannot be used as a User input pin like SV5.
This can be verified with the PCB layout of SHIELD_BTF3050TE. It is attached below for your reference,
Abhilash P
Please indicate on schematic what pin 1 SV6 is connected to?  Sorry but I don't see the connection to SW3 other than it is close to it.  Thank You.
Abhilash_P
  If you look closer in the PCB layout, it can be seen that it is connected to those pins.
Best way to verify this is by testing at your end.
Abhilash P
