User18637
12:10 AM
- Email to a Friend
I'm developing a project that using BLDC motor & Driver. And MCU for control motor driver. Also main supplu coming from battery. And when the system switch on it doesnt need to BLDC driver.
So i want to control BLDC driver's supply from BTS441TG Profet IC. I read the datasheet but some section doesnt clearly. BLDC motor nominal current 12A and its supplied from BLDC driver.
Actually i want to control Motor driver fro On/Off suplly voltage. But i cant find any resouce about how to driver BTS441TG. Do you have any sanple schematic? My BLDC driver supply 28 VDC
01:14 AM
- Email to a Friend
Please refer to the following links for automotive gate driver IC's for the required voltage range,
https://www.infineon.com/dgdl/Infineon-AUIR3240S-DS-v01_10-EN.pdf?fileId=5546d462533600a4015355a8358...
https://www.infineon.com/dgdl/Infineon-AUIR3242STR-DS-v01_00-EN.pdf?fileId=5546d462696dbf120169a1169...
Abhilash P
Abhilash P
01:14 AM
- Email to a Friend
Abhilash P
Abhilash P
