- Email to a Friend
As STATUS pin of BTT3018EJ is open drain pin, can we connect pull up to 3.3V in case of Vcc = 5V ?
- Email to a Friend
Hello PriyanshK,
Yes. It can be pulled to 3.3V when Vdd=5V.
STATUS Pin potential should be >2.6V in order to be detected as high by the internal logic when VDD=5V.
But if this STATUS pin input is given to an external microcontroller, please also check if the microcontroller is compatible with this potential.
Meghana
- Email to a Friend
Hello PriyanshK,
Meghana
