10:10 AM
- Email to a Friend
The data sheet shows the BTS6143 max voltage to part of Vbb = 38 volts. During a turn off cycle of an inductive load ,the output clamped voltage is limited to Von(CL) -42 volts. Is the drive FET rated to Vbb+Von(CL) = 80 volts under these conditions?
I will be operating the device 30 volt max with an inductive clamped output at -25 volts (two diodes). Is this within the ratings?
12:03 AM
- Email to a Friend
Can you please clarify why you have taken the Von(CL) as negative 42 volts?
Anshika
