Smart Power Switches Forum Discussions
jRn
First question asked Welcome!
Hello community,
I have a question about the BS50085 high side switch.
Why do I need an additional Z-diode Vzl / Vzb for reverse battery protection?
If Vbb disconnected with an inductive load, there should be an freewheeling diode. But why the Z-diode ?
Is there no reverse battery protection if I am adding this:
Thanks in advance.
Juergen
G_Anshika
Moderator 100 replies posted 50 solutions authored 100 sign-ins
Hello jRn,
Thank you for posting on Infineon Community.
Regarding the questions:
1.Why do I need an additional Z-diode Vzl / Vzb for reverse battery protection?
>>>When a reverse voltage is applied across a normal diode and a Z-diode , it is likely to happen that a normal diode would not survive the avalanche breakdown and may get permanently destroyed due to the sudden spike of current. But a Zener diode is designed to operate under this condition, hence providing reverse battery protection.
2. Using a power transistor(N-channel or P-channel MOSFET) is an alternative way of reverse battery protection.
You can also refer to this document for better understanding :
https://www.infineon.com/dgdl/Reverse-Batery-Protection
Anshika
G_Anshika
Hello jRn,
Anshika
