when i use wiced sensor tag(the red one) , i build the wiced_sense demo app in the IDE2.2 and download to the sensor tag,. My phone can 't find the device .
I push and hold the app button ,then set power and free the button , the device can be found. but app can't pair with mobile phone.
why?
WICED Sense
Hi senodia_terry,
Just wanted to clarify that you have performed a recovery on the WICED Sense. (video here WICED Sense Recovery Procedure Videoand/or reinstalled the app. I am using a galaxy S6 running android 5.0 and am having trouble reproducing the pairing problem.
If possible could you also try to connect using a different phone or WICED Sense so we can attempt to find the source of the problem.
Kevin
What phone and OS? iOS 8.3? Android 4.?
Note that there have been issues related to pairing on the latest versions of iOS.
My phone is android 4.2 .support ble4.1.
when i get the kit first , the device can be find ,and paird.
I am using android 5 on samsung s4. I can pair and connect to the newly update sense kit. I also used the wiced sense application (download from Play Store) to read the various environment parameters. Perhaps you may want to have a clean start by recovering your sense kit.
hi boont : thanks for your answer.
it is puzzle , I use the IDE2.2 build and download the Wiced Sense Demo app, to the wiced kit . The app in my phone has not changed .then it can't work. I don't think the sense kit has problem.
Hi senodia_terry,
Kevin
Any luck? senodia_terry
it seems work abnormal also. I have try many times . I feel a bit disappoint.
