In WICED-SMART-SDK-1.1.0,
bleprofile.h contains two functions, bleprofile_ReadUART and bleprofile_regHandleUARTCb.
What port are these functions using?
As Puart is independently set, I guess this UART is for HCI or debugging.
Hi eyan,
Those functions are for the peripheral UART, so you can communicate with another device. Here's an example I wrote that uses it to communicate with an Arduino DUE:
Hello eyan
Let me research this for you tomorrow
JT
Hello eyan,
Still working on this, but the bleprofile_regHandleUARTCb is a Registered Call Back function.
Does this help?
JT
JT,
can you answer what bleprofile_ReadUART is for?
EY
Hello eyan,
bleprofile_ReadUART:
Your application can call this function to read the content of the UART received buffer.
Your application needs to provide at least READ_UART_LEN
byte buffer
The Parameter:
data - This is the pointer to the buffer to read UART to.
Our API documentation is located in the SDK API.html file
Let me know if this answers your questions
JT
J.T, which port of UART does "bleprofile_ReadUART" use?
I'm confused with peripheral UART.
EY An
You can specify which port you use for peripheral uart like below.
const BLE_PROFILE_PUART_CFG sample_puart_config = {
115200
, GPIO_PIN_UART_TX
, GPIO_PIN_UART_RX
sample_puart_config is used as the 4th parameter of bleapp_set_cfg().
Hi eyan,
