Hi, I am trying to use long characteristic (50byte) with variable length.
I can set value to the characteristic once, but it never change if I try to update to another value.
I defined below LEGATTDB_PERM_READABLE and LEGATTDB_PERM_VARIABLE_LENGTH set characteristic.
CHARACTERISTIC_UUID128 (
HANDLE_MY_CHARACTERISTIC,
HANDLE_MY_VALUE,
UUID_MY_CHARACTERISTIC,
LEGATTDB_CHAR_PROP_READ | LEGATTDB_CHAR_PROP_NOTIFY,
LEGATTDB_PERM_READABLE | LEGATTDB_PERM_AUTH_READABLE | LEGATTDB_PERM_VARIABLE_LENGTH,
50),
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
I set value as below.
BLEPROFILE_DB_PDU* my_characterestic = cfa_mm_Alloc(2 + data_len);
memcpy(my_characterestic->pdu, data, data_len);
my_characterestic->len = data_len;
bleprofile_WriteHandleData(HANDLE_MY_VALUE, my_characterestic, 2 + data_len);
cfa_mm_Free(my_characterestic);
reproducible procedure.
1. connect BCM20737S(peripheral) and iPhone(central)
2. set value with bleprofile_WriteHandleData.
data is {0x01, 0x02, 0x03, 0x04, 0x05, 0x06} and data_len is 6.
3. read value from iPhone. {0x01, 0x02, 0x03, 0x04, 0x05, 0x06} can be read correctly.
4. set another value like {0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17} and data_len is 7.
5. read value from iPhone. {0x01, 0x02, 0x03, 0x04, 0x05, 0x06} remains even though another value has been set.
(if I set shorter byte array like {0x21,0x22,0x23,0x24,0x25} at step4, it can be set correctly..)
Can we use long characteristic with variable length?
Environment is as below.
Hardware : BCM20737S as BLE peripheral, and iPhone (iOS9.1) as BLE central
SDK : 2.2.0
Thanks boont,
This issue has been solved with below modification (enable to write).
With our use case, this characteristic don't need to write, but without "writable", I cannot use variable length even though adding LEGATTDB_PERM_VARIABLE_LENGTH.
- CHARACTERISTIC_UUID128 (
+ CHARACTERISTIC_UUID128_WRITABLE (
HANDLE_MY_VALUE,
- LEGATTDB_PERM_VARIABLE_LENGTH | LEGATTDB_PERM_READABLE | LEGATTDB_PERM_AUTH_READABLE,
+ LEGATTDB_PERM_VARIABLE_LENGTH | LEGATTDB_PERM_READABLE | LEGATTDB_PERM_WRITE_CMD | LEGATTDB_PERM_WRITE_REQ | LEGATTDB_PERM_AUTH_READABLE,
50),
Anyway, thank you for your support!
Hi boont ,
Thank you for your reply, but your link is about length of long characteristic data. In your linked article, 79rpm use LEGATTDB_PERM_VARIABLE_LENGTH flag, but I cant know s/he can handle long characteristic as variable length data...
There is a description of a fix here. Let me know if it helps:
Thanks boont,
HANDLE_MY_VALUE,
50),
