Often when central attempts to connect (connUp) with peripheral,
central serial port shows ""bleprofile_connDown stop Idle Timer"", and then it gets a connDown callback, but no connUp callback.
If you have an WiFi Access Point nearby sending high traffic on one of the advertisement channels it is indeed quite possible.
MichaelF_56
Hi Doug,
I wanted to let you know that we are looking into this issue (based on the first post) and will get back to you shortly with some feedback.
Thanks, m.
As a workaround, central now detects this condition, and immediately again attempts to start connection (connUp) again.  Sometimes, each connection attempt results in immediate connDown, but eventually there is connection and connUp callback.
Any news on this problem?  This is our only major issue with the Bluetooth communication.
Try to call emconinfo_getDiscReason, it might give you some clues as to why connection is going down.  In LE when central tries to establish connection it some times can get a connection up notification although connection has not been established completely.  That might be the cause of connection down callback being called.  Following is a quote from BT spec.
2.59 CONNECTION FAILED TO BE ESTABLISHED (0x3E)
The Connection Failed to be Established error code indicates that the LL initiated
a connection but the connection has failed to be established.
Will do.
Does emconinfo_getDiscReason() print the reason, or return something?
I tried it, but get no result.
Here is list of ble functions called, and ble output:......
S T A R T S C A N :
blecm_CreateConnectionCancel();
blecm_CreateConnection(
  blecen_cen_cfg.high_scan_interval,
  blecen_cen_cfg.high_scan_window,
  blecen_cen_cfg.init_filter_policy,
  peer_addr_type,
  (char *)peer_addr,
  blecen_cen_cfg.init_addr_type,
  blecen_cen_cfg.high_conn_min_interval,
  blecen_cen_cfg.high_conn_max_interval,
  blecen_cen_cfg.high_conn_latency,
  blecen_cen_cfg.high_supervision_timeout,
  blecen_cen_cfg.conn_min_event_len,
  blecen_cen_cfg.conn_max_event_len
bleprofile_connUp()
BLE_no_adv
C A L L B A C K  F O R     C O N N U P    O C C U R   S H E R E ...
smp timer started 01
smp conn down
smp timer stopped
bleprofile_connDown()
>>>  U N E X P E C T E D   C A L L   B A C K   FOR CONNDOWN   OCCURS HERE : ... <<<
emconinfo_getDiscReason() is now called, but doesn't do anything.
What does emconinfo_getDiscReason() return?
disc_reason is always 3e.
HERE IS DEBUG OUTPUT:
control_peripheral_connection( adr=1 )
- Start high speed connection with 1.
00:04:00 PWR RX comm: 13933=P1 0=P2 0=P3
bleprofile_connUp()
BLE_no_adv
callback_connection_start() #496 rtt(2)
peripheral's address=000000000001 hand=64
smp conn down
smp timer stopped
callback_connection_end() #496
connection_start_FAULT 91 <<<<<<<<<<<
Disc_Reason: 3e
bleprofile_connUp()
BLE_no_adv
callback_connection_start() #497 rtt(2)
smp conn down
smp timer stopped
callback_connection_end() #497
Disc_Reason: 3e
bleprofile_connUp()
BLE_no_adv
callback_connection_start() #498 rtt(2)
smp conn down
smp timer stopped
callback_connection_end() #498
Disc_Reason: 3e
bleprofile_connUp()
BLE_no_adv
callback_connection_start() #499 rtt(2)
smp timer refresh
smp timer refresh
smp timer stopped
callback_encryption_changed() #137
callback_connection_bond() #137
I seem to recall a previous response from the SW team explaining that if you receive 0x3e back during connection establishment, that you need to retry.
Oh, ok.  So it is normal -- perhaps caused by local RF 'conditions'?
Is it safe to again attempt connection (start connUp) from inside the connDown callback?
Or is it safer to wait a little, and attempt again from with the fine timer callback?
I checked with the developers and there shouldn’t be a problem attempting a new connection (start connUp) from inside the connDown callback.  In fact, they said either method should be fine.
We get multiple of those 3e errors per minute.
Is that normal Or a problem?
