Smart Bluetooth
TaSa_2191066
First like given
I'm newbie to wiced-smart platform.
Now I'm trying to make my device having a static random BD_ADDRESS, and read
Re: Static random device address
and already understood the mechanisms of wiced's static random address creation process.
But, when I insert following two lines in my _create() function
  UINT8 bd_addr[6];
  blecm_set_static_random_bd_addr(bd_addr);
with inserting following one line in top of my source code
  #include "blecm_set_static_bd_addr.h"
and build, make says:
  undefined reference to `blecm_set_static_random_bd_addr'
Is this function already deprecated?
If so, what is the name of the new alternative function?
Best,
Takashi
An update.
Adding one line into my makefile.mk in the last line resolved build issue.
APP_PATCHES_AND_LIBS += bd_addr_control.a
But again, the device just becomes FF:FF:FF:FF:FF:FF (because I appended BT_DEVICE_ADDRESS=ffffffffffff), and the Address Type bit is still set as Public (by looking at a sniffer provided by nordic).
Any one have a suggestion?
Best,
Takashi
Hello pukaso
1.  You need to perform a Clean and Build.
Please let us know the result
JT
TaSa_2191066
First like given
Dear j.t, boont,
thank you for suggestion.
I'll try it several hours later and report the result.
Best,
Takashi
TaSa_2191066
First like given
Dear j.t,
Clean and Build doesn't make difference. So the device still has a public address.
Best,
Takashi
Hello Takashi,
1.  blecm_set_static_random_bd_addr(bd_addr); - What was the return values of that function?
JT
TaSa_2191066
First like given
Hello JT,
the return of the function blecm_set_static_random_bd_addr() is 0, so it seems to be failed.
By using
blecm_startAdv(0x00,
   100,
   HCIULP_ADV_CHANNEL_MAP_MASK,
   HCIULP_RANDOM_ADDRESS,
   HCIULP_INITIATOR_FILTER_POLICY_WHITE_LIST_NOT_USED,
   NULL);
instead of
bleprofile_Discoverable(HIGH_UNDIRECTED_DISCOVERABLE, NULL );
, the address type have changed into random address, however,
the address now became all zeros: 0x000000000000.
I'll extract the key structure of the source in the form of such as edited version of mybeacon, and attach.
Best,
Takashi
BoonT_56
Is this still an issue? pukaso
TaSa_2191066
First like given
Dear boont,
yes, still I don't have a solution.
BoonT_56
I tried out your method and I was able to have a random bd addr whenever I power up, as opposed to the all zeros you have reported. I'm using the hello_sensor.c on the tag3, and wiced_explorer app on a samsung s4.
TaSa_2191066
First like given
Dear boont,
Thanks for checking re-occurrence.
I'm now doubting of hardware ( circuitry ).
Could you please pass your e-mail to share our confidential circuit data?
My e-mail is: sagisaka@ux-xu.com
Best,
Takashi
TaSa_2191066
First like given
Dear boont,
We don't have TAG3 now, so I cannot try it out right now, but one apparent difference between TAG3 and
our board is that our design doesn't have an external EEPROM.
Do you have any idea about how to make bd_addr_control.a adjusted for our design?
( Key structure around BCM in our design is extracted below )
Otherwise, we have to somehow prepare several thousand public addresses by the week starts at 21th June... 😞
Best,
Takashi
BoonT_56
I noted from Victor's reply that the app will create a random bd address upon booting up, after which this address will be saved in the NVRAM (eeprom). If you do not have an eeprom, then this could be an issue.
From whom are you getting your 736/737? Do you happen to work with Macnica or Tecstar?
TaSa_2191066
First like given
Yes, we've got our's from Macnica Tecstar.
I now got a BCM920737_LE_KIT, so am trying to follow your and dmiya's successful reports.
BoonT_56
pukaso
TaSa_2191066
First like given
Dear boont
We and the vendor could not find out the cause, so we finally bought our
OUI.
Static random seems not working on our board using 20737S depicted above.
If you have already succeeded in ena bling the feature on any board with
20737S, I hope you to include the schematic and code into newer SDK
releases.
Best,
Takashi
2015/06/17 11:14 "boont" <communities-list@community.broadcom.com>:
<http://community.broadcom.com/?et=watches.email.thread> undefined
reply from boont
<http://community.broadcom.com/people/boont?et=watches.email.thread> in *WICED
Smart Forums* - View the full discussion
<http://community.broadcom.com/message/16685?et=watches.email.thread#16685>
BoonT_56
Just to clarify, what did you buy? What is OUI?
TaSa_2191066
First like given
We bought our IEEE's Organizationally Unique Identifier, to write public
address in our product.
2015/06/17 12:51 "boont" <communities-list@community.broadcom.com>:
reply from boont
<http://community.broadcom.com/message/16706?et=watches.email.thread#16706>
BoonT_56
Did you have a chance to try out JT's suggestion?
