hachc_2137126
  Referring to post Connection Interval and Connection Slave Latency What if we need the 20737 as master role to change the parameter to slaves? Any other API?
lel2cap_sendConnParamUpdateReq() can be used anytime when there is a connection (so outside connection up callback is OK too) with a peer device. This however is only a request from the slave to the master to change the connection parameters (only the master can change these).
  Another question is about the call back function 'lel2cap_handleConnParamUpdateReq', is this the callback when parameter update request coming from master or slave role or BOTH?
MichaelF_56
Moderator 250 sign-ins 25 comments on blog 10 comments on blog
" Do we have further comment on the usage of callback 'lel2cap_handleConnParamUpdateReq'? And how does a master (20737 running as master role) to handle different connection update requests coming from different slaves?"
Take a look at Proximity_Client as I believe it handles multiple requests from different slaves at a fairly frequent interval.
MichaelF_56
Adding maxsong from our support team in Asia.  Max recently provided us this very detailed submission on how to test master and slave configuration: Testing Master and Slave Roles
hachc_2137126
  Unfortunately, I don't see the answer about the usage of callback 'lel2cap_handleConnParamUpdateReq' from post Testing Master and Slave Roles.
MichaelF_56
hachc_2137126
Thanks, mwf_mmfae.
From proximity_client, api
blecm_ConnectionUpdate(
                blecen_con_handle,
                blecen_cen_cfg.high_conn_min_interval,
                blecen_cen_cfg.high_conn_max_interval,
                blecen_cen_cfg.high_conn_latency,
                blecen_cen_cfg.high_supervision_timeout,
                blecen_cen_cfg.conn_min_event_len,
                blecen_cen_cfg.conn_max_event_len)
Can be used for specifying connection parameter to each slave connection.
