Step 1: Central connects to and bonds with peripheral-1, writes request, gets notification, disconnects.
Step 2: Central then connects to and bonds with peripheral-2, etc.
Step 3: Central then tries again with peripheral-1; central and peripheral-1 both get ConnUp callback, but neither gets bond result callback (lesmp_regSMPResultCb).
Hello Jason,
Here is what we believe the behavior of your use case:
1.  The Central and Peripheral are already bonded.
2.  Therefore, the bonding will not occur again.
3.  If security was enabled, you will get an encryption complete call back as a result.
Hope this helps,
JT
MichaelF_56
Moderator 250 sign-ins 25 comments on blog 10 comments on blog
Are you using the BCM920732 Tag board?
Which of the included ROM/RAM based profiles are you using for your testing?
Are you enabling anything within BLE_PROFILE_CFG to enable Pairing/Bonding?
I will check with the developers.
I'm getting this behaviour, was it ever established what was going on?
Hello Jason,
Hope this helps,
JT
