Hello
I am trying to get an eval-board of type CYBLE-013025-EVAL to run with the example puart-controll from WICED-Smart-SDK. But since I am new in this matter, I ask for support. Downloading to the eval-board worked, but searching for a device in the provided software "ClientControl" does not work.
Can anyone help me with this?
Cheers
Timon
Hello AnjanaM_61
I finally got it running. I don't know why, but it didn't work via the USB interface. Now I used a RS232 converter to connect the two pins P0 and P2 to the computer. This seems to work.
Thanks a lot for your help.
Cheers
Timon
There is a document in the example project folder itself. Puart-control.pdf. Did you followed the steps ? Can you please confirm.
Also , you may have to change the uart pins with respect to the module. I would suggest you to go through our getting started appnote for this module once:
Anjana
Hello
Thanks for your replay.
I saw this document and tried to follow them. But there must be somewhere a tiny error in my code that it does not work for me.
I connected the board together with the cable which was also delivered in the kit into the computer. I put the pin 1-4 OFF and the pin 5, 6 from the switch 1 ON. Then I can download and receive the answer that it was successful.
But when I start the ClientControl it does not to anything. I also downloaded the right file from the platform and tried to change the UART_PIN’s but it still does not work.
I tried with these pin configurations:
#define GPIO_PIN_UART_TX 24
#define GPIO_PIN_UART_RX 25
#define GPIO_PIN_UART_TX 0
#define GPIO_PIN_UART_TX UP_TX
#define GPIO_PIN_UART_RX UP_RX
I would be more than happy if you have some hints for me.
Timon
Hello AnjanaM_61
Cheers
Timon
