Hi All,
So far, as we knew the fine timer is the SW timer and was driving by App thread and we have to use the timer to implement loop.
We require to have the periodic 20 Hz timer (uniform) to access sensor data and also need to calculate the senor data.I have some question.
1.The max escape time value of fine timer, if I configured fine timer to 20 Hz. The value shall not affect the BLE stack behavior
50ms is fine.
2.How to guarantee the uniform interval timer.what's delta time of the each tick .
12.5ms
3.Can we have the independent HW timer to access sensor rather than the SW timer.
Better not to use HW timer but we have seen 6.25ms
Br,
BB119
Timers
Question 1:
I want to know how long can we still in timer and not affect the BLE stack. for every tick, can we execute our application code around 25 ms (fine timer:50ms)
Question 2:
Was interval of timer uniform ? my senor will be report the value every 50ms, We have to read value every 50ms. (+- 3 ms), otherwise data may lost.
Hello Barrel
Let us research your 2 other questions.
2. The fine timer tick is 12.5 ms resolution.
JT
Question 1:
Question 2:
