Smart Bluetooth
Hi All,
I'm checking the iBeacon reference board and relalize that the board is using BCM20737.
As I know iBeacon is pretty simple application and BCM20732 should be work well.
Any idea on chip selection?
Benson
MichaelF_56
Moderator 250 sign-ins 25 comments on blog 10 comments on blog
As it turns out, the two iBeacon samples included within SDK 2.X depend on a patch/library that will only work on the BCM20736/7 (A1 Firmware, SDK 2.X support).
We are not including the patch within the SDK release (application source will be there) because we need to also make sure that we give the library to MFI licensees only.
We are working on a process to verify MFI licensees now and the code will most likely be distributed on a seperate MFI website that is accessible via invite only.
