11:47 PM
Mar 26, 2017
11:47 PM
HI, I'm working with BCM 20737. The application uses the DEEP SLEEP mode, waking up via GPIO. It works fine, but now I need to recognize a wake up from DEEP SLEEP from a POR (Power On Reset) : Both stars with a bootstrap and passes through an APPLICATION_INIT. My question is There is a uController register I can check in order to recognize the difference ? Can You provide any axeample ?
Giuseppe
01:19 AM
Mar 27, 2017
01:19 AM
01:19 AM
Mar 27, 2017
01:19 AM
Let me know if the below helps.
Mar 27, 2017
02:21 AM
Mar 27, 2017
02:21 AM
Yes, It works.
Issue solved.
Thanks a lot, btta
Kind regards,
Giuseppe
