i am new to Broadcom and as i am beginner, could you please help me at the first step with the following issue which i have attached screenshot in the attachments.
i just opened the file in IDE and i could able to acknowledge this errors from the default programs (i did not change anything from the default code).
please help me to understand the behavior of the same... and what i suppose to do to remove those errors
thanking you....
Hi rsiddhanth
You don't have to worry about those errors. Go ahead and take a look at this thread for more information about them and how to turn them off: Eclipse IDE compilation errors You should use the "Make Target" window in the upper left corner of the IDE to build the application that you want to try.
Hope this helps!
Hi rsiddhanth
Hope this helps!
thank you very much Lucyli
Yes, thanks a ton lucyli​!
Have a nice weekend.
