hi,
now, i try to use bcm20737 to connect a humidity sensor.
the humidity sensor format is as following.
could any i2c API access the data?
or is there any more underlying function to access it?
This format is not supported by 2073x.
The Hold Master Mode failed for us but the No Hold Master Mode worked perfectly in our test firmware.
We use the cfa_bsc_OpExtended() call to read and write I2C commands.
Oooops, there was a typo in my previous post (Hold Master Mode and No Hold Master mode were swapped):
The No Hold Master Mode failed for us but the Hold Master Mode worked perfectly in our test firmware.
So the I2C sequence you describe failed for us.
