I've looked at the hello_client example and used it to communicate with the hello_sensor. It works great.
However the communication goes one way:
* 7. Push a button on the hello_sensor to deliver notification through
*    hello_client device up to the client.
I would like to send a notification from the hello_client to hello_sensor. I tried modifying the sample code provided, but did not succeed yet. If you could provide an example on how to do this it would be very helpful. Thanks.
ArvindS_76
Clients don't send notifications to a server. Clients only send read/write requests and commands. The hello_client sample already does this using bleprofile_sendWriteReq(). See bleprofile_sendWriteReq, bleprofile_sendWriteCmd and other bleprofile_sendRead* functions in bleprofile.h
ArvindS_76
great this helps. Thanks!
uncommenting:
bleprofile_sendWriteReq(HANDLE_HELLO_SENSOR_CONFIGURATION, (UINT8 *)&u8, 1);
got me started
