- Email to a Friend
- board
- button1
- button2
- button3
- buttons
- buttonsinputslowinterrupt
- configure
- defined
- guessing
- hello_sensor.c
- hello_sensor_interrupt_handler
- initialize
- inputs
- interrupt
- press
- realize
- registers
- value&0x01
- value&0x021
- value&0x042
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
- SW1 pin4/VDDIO was measured to be 1.812V.
- SW1 pin 1 was measured to be 1.614V.
- When I pressdown SW1, the voltage goes to 1.796V.
- Email to a Friend
Hi all, I am new to the forum, I was trying to build a program for the BCM20732. When I choose Build Target in the Make target window, the problem says :
12:44:48 **** Build of configuration blood_pressure_monitor-BCM920732TAG_Q32 for project WICED-Smart-SDK ****
"C:\\Users\\vyin\\Documents\\WICED\\WICED-Smart-SDK-1.1.0\\WICED-Smart-SDK\\make.exe" test
make: *** No rule to make target 'test'. Stop.
12:44:48 Build Finished (took 317ms)
Anybody knows how to result the issue?
Thanks a lot.
- Email to a Friend
Are you attempting to build/program to a BCM920732 Tag board using the following make file: RAM.hello_sensor-BCM920732TAG_Q32 download
If yes, what if any changes have you made to the example code?
Which Windows based SDK are you using?
I'm using SDK 1.1.0 and am seeing a clean console output based on the provided application code (see below):
13:24:26 **** Build of configuration blood_pressure_monitor-BCM920732TAG_Q32 for project WICED-Smart-SDK ****
"C:\\Users\\mfortner\\Documents\\WICED\\WICED-Smart-SDK-1.1.0\\WICED-Smart-SDK\\make.exe" RAM.hello_sensor-BCM920732TAG_Q32 download
Linking target ELF
OK, made elf.
Writing Hex image
Call to hello_sensor_spar_crt_setup @ 00209641
OK, made C:/Users/mfortner/Documents/WICED/WICED-Smart-SDK-1.1.0/WICED-Smart-SDK/Wiced-Smart/spar/../../build/hello_sensor-BCM920732TAG_Q32-rom-ram-Wiced-release/A_20732A0-hello_sensor-rom-ram-spar.full.hex.
OK, made C:/Users/mfortner/Documents/WICED/WICED-Smart-SDK-1.1.0/WICED-Smart-SDK/Wiced-Smart/spar/../../build/hello_sensor-BCM920732TAG_Q32-rom-ram-Wiced-release/A_20732A0-hello_sensor-rom-ram-spar.cgs. MD5 sum is:
51eeb6b9e0d41f8ea7731d50350188ab *../../build/hello_sensor-BCM920732TAG_Q32-rom-ram-Wiced-release/A_20732A0-hello_sensor-rom-ram-spar.cgs
Patches start at 0x00205918 (RAM address)
Patches end at 0x00208B1C (RAM address)
Application starts at 0x00208A08 (RAM address)
Application ends at 0x0020963D (RAM address)
Patch size (including reused RAM) 12804 bytes
Patch size 12528 bytes
Application size 3125 bytes
Total RAM footprint 15653 bytes (15.3kiB)
Converting CGS to HEX...
Conversion complete
Creating OTA images...
Conversion complete
Detecting device...
Device found
Downloading application...
Download complete
Application running
13:24:50 Build Finished (took 24s.71ms)
- Email to a Friend
Thanks you so much for your quick response. Here are my steps to have these problems.
1) I try to build/program to a BCM920732 Tag board
2) I chose a project in the Projector explorer panel on the left side of the IDE
3) I right click a project such as Automation_IO and choose “Make Targets” and then “Create” to have below window:
4) Target (test1) was created in the Make Target panel on the right part of IDE as below
5) I right click the “test1” target and choose “Build target” and get the error message:
13:44:11 **** Build of configuration blood_pressure_monitor-BCM920732TAG_Q32 for project WICED-Smart-SDK ****
"C:
Users
vyin
Documents
WICED
WICED-Smart-SDK
make.exe" test1
make: *** No rule to make target 'test1'. Stop.
13:44:11 Build Finished (took 169ms)
6) I wonder what’s the rule to build a target. The error happens to all the project on the left panel of Project explorer.
However if I “Build target” for the existing target files it works fine. See below:
7) So I must did something wrong, or my IDE has a wrong settings. Please help me. Thanks. My settings are:
- Email to a Friend
Go here and download the Quick Start Guide: WICED Smart Documentation
Take a look at the "Building your First App" sample...
This method of copying, then pasting and renaming a new target in the right hand Make Target window is what I've used.
For custom development, you will also want to copy an existing sample App such as Automation_IO by right-clicking on the Project folder and copying the project. You will then want to paste and rename it back into the Apps/RAM folder with a new name (this will preserve the original example app).
Within the Make Target window on the right, you will want to make sure your cut and pasted copy also has the same name as your renamed project folder, for example if you named the new project "newwidget" you would want the copied Make Target named RAM.newwidget-xxxxx
- Email to a Friend
Dear there,
Thanks for your help again.
I followed the procedure in page 11 of 23 in the attached guide. It still shows errors:
1) Copy “RAM.automation_io-BCM920732TAG_Q32 download target”
2) Paste it to same place to have “Copy of RAM.automation_io-BCM920732TAG_Q32 download”
3) Build Target for it, the error is
17:22:59 **** Build of configuration blood_pressure_monitor-BCM920732TAG_Q32 for project WICED-Smart-SDK ****
"C:
Users
vyin
Documents
WICED
WICED-Smart-SDK
make.exe" Copy of RAM.automation_io-BCM920732TAG_Q32 download
Makefile:173: *** Platform makefile not found: Platforms//.mk. Stop.
17:22:59 Build Finished (took 124ms)
4) I think if you uninstall your IDE and reinstall it by default, you may see same problem. I don’t know how my problem happened and how to fix it, file path is wrong?
Victory
- Email to a Friend
Hi Victory,
Read the instructions carefully. When you rename remote the "Copy " in the beginning and you will be fine. Good luck.
Victor
- Email to a Friend
Hello Victor,
I have problem also after I rename a target file from RAM.automation_io-BCM920732TAG_Q32 download to ROM.automation_io-BCM920732TAG_Q32 download
18:36:13 **** Build of configuration blood_pressure_monitor-BCM920732TAG_Q32 for project WICED-Smart-SDK ****
"C:
Users
Victory
Documents
WICED
WICED-Smart-SDK-1.0.1
WICED-Smart-SDK
make.exe" ROM.automation_io-BCM920732TAG_Q32 download
makefile:52: ../../Apps//makefile.inc: No such file or directory
makefile:96: "Warning: ELF_LIST is undefined."
makefile:96: "Warning: NUM_PATCH_ENTRIES is undefined."
makefile:96: "Warning: PATCH_ENTRY_SIZE is undefined."
makefile:96: "Warning: LMPREV is undefined."
make.exe[1]: *** No rule to make target '../../Apps//makefile.inc'. Stop.
Makefile:277: recipe for target 'ROM.automation_io-BCM920732TAG_Q32' failed
make: *** Error 2
18:36:13 Build Finished (took 468ms)
1) Can you send me your IDE’s file path, C++ build settings and behavior settings? I want to compare if it is same as mine.
2) Can I set up a webx so you can my screen so that you can help to figure out problem?
3) Can you see my emails below if you can find something wrong?
Victory
"C:
Users
vyin
Documents
WICED
WICED-Smart-SDK
Victory
"C:
Users
vyin
Documents
WICED
WICED-Smart-SDK
make.exe" test1
- Email to a Friend
Hi Victory,
If you look carefully at the target name for example "RAM.automation_io-BCM920732TAG_Q32 download". The first part is the name of the directory under Apps which is "RAM". After dot there is a name of a subdirectory which is "automation-io". This is the place where build process is looking for makefile.inc. Then there is a name of the directory under Platforms which specifies for what platform you are building "BCM920732TAG_Q32". The rest are not arbitrary words but something that make understand. For example the word "download" indicates that you want to download resulting image to the tag. If you change RAM.automation-io to ROM.automation-io, it will not build because there is no directory ROM.automation-io. Also putting random word "target" in the string will not help things up.
To build and download the image you need to double click on the application under Make Target in the top right pane of the IDE.
If you want to clean everything up, uninstall the package and then delete all the user files that were installed. By default they are in users\<user name>\Documents\WICED directory.
Good luck,
-Victor
- Email to a Friend
Hi Victor,
Thanks a lot. This is very helpful. I’ll try tomorrow. How can find you later on if I still have other issues?
Thanks again.
Victory
- Email to a Friend
I am on the East Coast :-). Post the message on the board and we will take care of you!
- Email to a Friend
Hello Victor,
We are tempting to program the connect BCM20732S with BCM20732TAG_Q32 JTAG connector. We did this way with bare SIP chip (no PCB, only soldered wires to the chip) to connect to the JTAG and the Smart IDE doesn’t detect the SIP chip when building target. The dip switch was switched on-off-on-off. So the issue is not from here.
Can you check if we missed something?
Victory
The JTAG connecter on the BCM20732TAG_Q32 is as following:
· BCM20732TAG_Q32 JTAG Pin 1 = UART Tx which needs to go to BCM20732S UART Tx Pin 19
· BCM20732TAG_Q32 JTAG Pin 2 = GND which needs to go to BCM20732S G GND Pins 2, 4, 5, 6, 7, 8, 9, 11, 12, 13, 14, 15, 16, , 17, 20. 23, 24, 29 , 38, 45, 46, 47, 48
· BCM20732TAG_Q32 JTAG Pin 3 = UART Rx which needs to go to BCM20732S UART Rx Pin 18
· BCM20732TAG_Q32 JTAG Pin 4 = VBAT which needs to go to BCM20732S VBAT Pin 3
The chips pin map is
The JTAG connector on the BCM920732 Tag board is:
Connecting:
3 Battery +
18 UART_RX
19 UART_Tx
2 GND.
- Email to a Friend
You are attempting to program the BCM20732S directly? Via a header connected to the HCI UART?
You may find these instructions helpful: Information: Programming your BCM20732S-based board from an onboard UART header
What's key is that you power your board up while making sure that RXD is held high during power up. This will put the part into Programming mode. Otherwise, if low, it will default to Application mode.
The best bet here is to work with your local distributor/BRCM Sales to obtain a BCM20732S Evaluation board and a BCM920732 Tag board, then use the Tag board to program the 20732S Eval Kit. There is a doc we can send that walks you through this methodology if you end up using it.
- Email to a Friend
Hi Victor,
It worked for me. Thanks.
For the naming convention below you mentioned, where can I find the official documentation for it because I want to know if there are other thnings I need to pay attention.
Thanks a lot,
Victor
