I'm using WICED SDK V2.1.0 and BCM20737S as slave role, when i enable pairing and bonding, after the cellphone bonds with BCM20737S successfully, i change the passkey of BCM20737S and reset, the cellphone can connect to BCM20737S without any validation, no need to enter 6 digital PIN code. Any comments?
BLE_PROFILE_CFG
Security
I have no issue. Are you doing the following?
// Uncomment the following line to enable OOB pairing. Change oob_tk[] below to the desired key.
// #define OOB_PAIRING
// Uncomment the following line to enable passkey pairing. Change passKey[] below to the desired key.
#define PASSKEY_PAIRING
You may want to "unpair" or "forget device", depending on what phone you are using, before you go through the whole discover-and-pair cycle again.
Btw, you may want to upgrade to 2.2.2.
So is this still an issue?
Yes, i use iphone6 with lightblue to test, should i must upgrade to 2.2.2 to fix this issue?
That will be a good idea.
Make sure to check if the 20737S device is showing on the device list in your smartphone bluetooth settings. This will cause a problem as it will not attempt to pair again. You need to "forget the device" for 20737S and attempt a fresh pair. For instance, in an iOS device go to Settings->Bluetooth->My devices and select the information for the hello_client device->select "Forget This Device". Then using LightBlue when you select the hello_client device it will pop up the option to pair or not. Hope this helps.
Jaeyoung
